Grabrails, inside and out
jwskawski
After extensive internet research I can't seem to pin down a construction detail.  On our 1992 Cat 36, it appears that the interior and exterior grabrails are mated up.  I have four "small" leaks along two badly weathered chipped and split rails.  I am thinking we will have to drill out the bungs inside and out to pull them apart for the new exterior ones to be properly rebedded.  This is a little distressing since the interior rails look beautiful.  Collateral damage is likely no matter how careful we are, and a total refinishing will probably be in order.
J Wm Skawski
Tranquility
1992 Wing
#1176
Yours is a Mk1 like ours, albeit 7 years newer. As can be seen in the attached photos, the screws for the outside rails are accessible from the inside in a line of screwheads outboard of the inside grab rails, and vice versa the fasteners for inside rails are visible on the outside in a line on screwheads inboard of the outside rails. I take it yours doesn't look like this?
jwskawski
We don't have anything like what your pictures show...Thanks tho!
J Wm Skawski
Tranquility
1992 Wing
#1176
To easily and correctly remove bung plugs see;  ​https://www.youtube.com/watch?v=9wV7h_lIqsc
Defender has 3/8 plugs and it easier to buy them than to make them.
jwskawski
Thanks for the input...bound to end up refinishing the interior one!
J Wm Skawski
Tranquility
1992 Wing
#1176
