New Trash Container
ProfDruhot's picture
ProfDruhot
New Trash Container
I have recently come to the conclusion that the rather large waste can that was mounted in the galley was too big. So, I removed it and sold it at a local consignment shop and completed the following project. As you can see in the photo I connected the two drawers together (internally) in the galley. I removed the bottom piece of wood on the top shelf. Then I located a small plastic wastebasket that fits perfectly. What an easy upgrade this turned out to be!
Well, I just attempted to upload a picture of this project and apparently it is too large. Stu, what do I do here buddy?
ProfDruhot
Perhaos Larry can assist me with this technical glitch.
Make sure your photos do not exceed 320kb and they should attach just fine.
John Reimann's picture
John Reimann
I found that changing a photo to pdf format vastly lowers the amount of bites it takes up. If you can "print" to pdf, you might want to try that.
SF Bay
1998 C36
