I have recently come to the conclusion that the rather large waste can that was mounted in the galley was too big. So, I removed it and sold it at a local consignment shop and completed the following project. As you can see in the photo I connected the two drawers together (internally) in the galley. I removed the bottom piece of wood on the top shelf. Then I located a small plastic wastebasket that fits perfectly. What an easy upgrade this turned out to be!
Well, I just attempted to upload a picture of this project and apparently it is too large. Stu, what do I do here buddy?
Perhaos Larry can assist me with this technical glitch.
Glen [url]http://c34.org/bbs/index.php/topic,4053.0.html[/url]
Make sure your photos do not exceed 320kb and they should attach just fine.
I found that changing a photo to pdf format vastly lowers the amount of bites it takes up. If you can "print" to pdf, you might want to try that.
SF Bay
1998 C36
