Which roller furlers?
dsp36's picture
dsp36
Hi, new to sailing and enjoying learning all i can. I think my foresail has a Shaeffer 2100 roller furler?
And which type does my mainsail have please?
Thank you,
Steven
"Nauti Seahorse"
2001 C36 MK ii. #2011
Looks to be the same as ours which is from Charleston Spar. This site has some good tips on furling the main.
dsp36's picture
dsp36
Thank you. That's what I was thinking.  And the foresail furler is a Shaeffer 2100, I think.
"Nauti Seahorse"
Brazen
Here is a handbook for the Charleston Spars furling mast. THere are large phillips screws in the mast above and below the furling mechanism. Start putting some PB Blaster on them a week or so before attempting to remove them. Several applications and a manual phillips impact driver (Harbor Freight sells one for less than $20) will accomplish the task without wrecking the head of the screw.
Denis
Brazen Article #1925
2001 Catalina 36 MKII
PDF icon Catalina 36 Furling Mast handbook1.87 MB
Brazen
Here is a single page parts sheet for the Schaeffer 2100
Denis
PDF icon Schaeffer 2100 Parts list218.72 KB
Brazen
Here is a single page parts sheet for the Schaeffer 2100. They make a longer toggle (the part above #41 in this drawing.
It allows modern anchors to roll off the bow without hitting the bottom of the furler. It is an expensive piece of stainless steel but I bit the bullet and purchased it for about $325. After a couple years I'll now say it was and is worth the price.
Denis
dsp36's picture
dsp36
Good info. Thank you!
"Nauti Seahorse"
