Wondering about installing a self tending jib system and wanted some input from anyone who has some experience with them. I currently have a 1989 36ft tall rig with a roller furling jib. Is it feasible to reef the jib to make it work with the self tacking system? How do you run the sheet rope? I've seen 2 ways, up the mast then back down, or forward to a block, then back to the cockpit. What is it like on a beam or broad reach? I'm sure I have more questions, but lets start with these. Thanks in advance.
Bill Deliman
Vivacious 2
Atlantic Highlands, N.J.
Bill-
Not able to answer your questions....but something to consider. If you have 135 Genoa and plan on using that, you will probably lose a lot of sail shape by the time it's furled short enough to swing by the mast. This would largely limit it to a broad reach or down wind sail. Self tending set ups are best for upwind tacking. From my experience, furling a 135 beyond about 30% degrades the sail shape for upwind sailing. I think your talking about a cutter rig which would require a dedicated smaller jib and second forestay lower on the mast and positioned behind the existing one on the bow.
2005 C36 MKII #2257
