Adding studs to mast ring for new turning blocks
H20Buoy
Hi All,
I've just purchased a new-to-me 1992 C36 Mk 1.5 with tall rig.  The mast ring at the base of the mast has studs sticking up to mount the turning blocks for halyards etc that go back to the cockpit.  I plan to run many more lines back aft (reefing, vang, main halyard and cunningham) so I need to add some studs to mount more turning blocks.
The ring doesn't appear to have any vacant holes or indication of where to place new holes.  I plan to put 1 on each side of center on the aft side of the mast and one more on the port side in addition to the pre-existing studs.  Has anyone else done this?  Any issues I need to be aware of?
Thanks in advance for your help.
Bryan
S/V 'Wind Chase',
Victoria BC
1992 C36 Mk1.5, TR/FK, #1174
Sojourn's picture
Sojourn
Hi Brian,
I did that a couple of years ago.  I removed the collar and took it to a local machine shop.  The holes need to be counter sunk on the bottom for the flange for the mounting studs,  I took one of the newly purchased studs from Catalina Direct, so they would have its dimensions.  I'll try to get a photo later.  The cost was about $100.00.  It is easy to do if you have the tools, I didn't.
Regards,
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
H20Buoy
Thanks Lou.  That means the mast has to be off to do the machining.  I don't plan to remove the mast till spring.  Maybe I'll drill and tap some threaded holes from above and fasten in a pad eye instead.  I'll let you know how it goes.  Thanks for the info!
Bryan
S/V 'Wind Chase',
Victoria BC
Sojourn's picture
Sojourn
Bryan,
We have run all the lines aft:  halyards, vang (we have a ridged vang, no topping lift), outhaul, and reef lines (2 each tack and clew reef lines).  We do not need to go forward to reef.
Lou
Lou Bruska
Sojourn
Eldean Shipyard
