Did any of you ever replace the discharge hose running from the electric bilge pump? Mine has a leak in it just before it exits the boat near the transome. I have had it duct taped for years. Ran out of other projects so it's time to fix this one. I have the corrugated type now but I remember reading somewhere about using a smooth walled hose that would be better? Any advice/comments appreciated.
Pat T, 1995 TR, wing keel, #1388
"Liberty Call"
Burnham Harbor, Chicago
I replaced both my electric and manual bilge hoses recently with the smooth inside type hose. The originals were very brittle. I used Shields 141 Series, Multiflex Bilge Hose, Black, 1-1/8" for the auto electric bilge that fits the Rule 2000 port (1 1/8"). The Manual hose that goes to the whalegusher manual pump (which I also changed out) is same stuff but in 1 1/2". I got mine at Go2Marine.com. Their sku for the 1 1/8" is 469019. I bought it on sale last year but it's now $1.41 per foot. I bought 34 feet of the 1 1/8" and ended up cutting off a few feet but can't remember how much. The 1 1/2" only seemed to come in a 50' roll so I have a bunch ofd that left over. Don't use a check valve, it's just another thing to fail or stick closed when you most definitely don't want it to. Also the 1" size I used to replace all my water tank fills.
Tad Davis
Simpler Times
1989 C-36 MK I #1004
Redondo Beach, Calif.
Thanks guys, good info. Especially wanted to know how much hose to buy. I looked at it a litter closer and it is not a straight shot aft from the pump to the transome. It does snake a bit but 34 feet sounds like a good number.
"Liberty Call"
FYI, mission accomplished. Purchased 34 feet of hose but used less than 30!
"Liberty Call"
