Pat T
Last seen: 3 months 7 hours ago
Replacing bilge discharge hose
Did any of you ever replace the discharge hose running from the electric bilge pump? Mine has a leak in it just before it exits the boat near the transome. I have had it duct taped for years. Ran out of other projects so it's time to fix this one. I have the corrugated type now but I remember reading somewhere about using a smooth walled hose that would be better? Any advice/comments appreciated.
Pat T, 1995 TR, wing keel, #1388
"Liberty Call"
Burnham Harbor, Chicago
"Liberty Call"
Last seen: 16 hours 40 min ago
Smooth is much better especially if you have the type with collars at the ends. You’ll get better flow, and less odor with the smooth.
TadTV
Last seen: 2 months 1 week ago
I replaced both my electric and manual bilge hoses recently with the smooth inside type hose. The originals were very brittle. I used Shields 141 Series, Multiflex Bilge Hose, Black, 1-1/8" for the auto electric bilge that fits the Rule 2000 port (1 1/8"). The Manual hose that goes to the whalegusher manual pump (which I also changed out) is same stuff but in 1 1/2".   I got mine at Go2Marine.com. Their sku for the  1 1/8" is ​469019. I bought it on sale last year but it's now $1.41 per foot.  I bought 34 feet of the 1 1/8" and ended up cutting off a few feet but can't remember how much. The 1 1/2" only seemed to come in a 50' roll so I have a bunch ofd that left over.  Don't use a check valve, it's just another thing to fail or stick closed when you most definitely don't want it to.  Also the 1" size I used to replace all my water tank fills.
Tad
Simpler Times
1989 C-36 MK I #1004
Redondo Beach, Calif.
Pat T
Thanks guys, good info. Especially wanted to know how much hose to buy. I looked at it a litter closer and it is not a straight shot aft from the pump to the transome. It does snake a bit but 34 feet sounds like a good number.
"Liberty Call"
Pat T
FYI, mission accomplished. Purchased 34 feet of hose but used less than 30!
"Liberty Call"
