Mermaid Condensator
True Wind
Mermaid Condensator
I have a 16K Mermaid ac unit. I installed a venturi condensator valve about two years ago from Mermaid and paid about $200.00. It stopped working even though it has been throughly cleaned. Mermaid would do nothing about it. So I found out where they get theirs from. It's only $45.00.
2003 Catalina 36
Parsons's picture
Parsons
Thanks - I was about to buy this Marvair kit from Defender for $160, but this is packaged with all the tubing and clamps (a $50 value!).  Before it failed, how did yours work?  https://www.defender.com/product3.jsp?path=-1|6880|2061076|2061077|2061085&id=2756613
John Parsons
Tall Rig, Fin Keel
Bay City, MI, USA
dpower
I have had this condensator on our boat for over 18 years. It works great to remove the condensation coming off the air con..But, it requires some maintenance. Periodically, I clean the strainer in the discharge line off the condensation drop pan. I will also replace the tubing from the strainer to the unit as it becomes quite dirty, as does the back flow preventer in the nipple attachment on the condensator. I actually removed that back flow preventer and added an inline preventer immediately after the strainer. Finally, I did have a small barnacle in the condensator one time. Overall, I would not run out system without a condensator.
David S. Power
Two If By Sea #1687
Burnt Store Marina
Parsons's picture
Parsons
Which condensate remover do you have, the Marvair or the Mermaid that True Wind talks about?  Want to know before I install one.  Thx.
John Parsons
Tall Rig, Fin Keel
Bay City, MI, USA
dpower
I have a Mermaid.
David S. Power
Two If By Sea #1687
Burnt Store Marina
True Wind
When it works it works well. I spoke with Tom at Mermaid and he said that on occasion they will get a condensator in that for what ever reason will not work no matter what you do with it. He didn't know why that is.
2003 Catalina 36
