Transom board
jswesterman
Transom board
Hi,
I have a C36 Mk II.  While the step thru transom is very nice it does let waves into the cockpit in a following sea.  The transom gap has slots on either side that appear to be for a board to be dropped in to block the gap.  I've searched widely but cannot seem to find any reference to a board to drop into the slots.
Does anyone have any idea if such a board originally came with the C36 and if one can be purchased somewhere?
Jeremy
Jeremy Westerman
"Odette", 2005 Catalina 36 Mk II, #2213
Benicia, CA
Jeremy,
I have a Ml with the walk trough and it is a piece of acrylic tinted on my boat that fits in the slot. It has a teak trim board across the top , teak as well for the sides, and is 1-2" off the cockpit floor for drainage. Basically it would keep items from going out of the cockpit. I never have had any issue with a following sea entering.
jswesterman
Gary,
Thanks for the info - sounds just what I need.  Did this come with your yacht or did you have it custom made?
Jeremy
Jeremy Westerman
Benicia, CA
sseltzer's picture
sseltzer
I have the same filler piece that Gary described. It came with the boat and the PO called it a "poodle catcher".
Steve
jswesterman
Gary and Steve - thanks for the info.  Based on this info I contacted Catalina Yachts and they can supply it - they call it a "doggie catcher" and it costs $85.00.  Last time I sailed out the Golden Gate I did get my feet wet with following seas and so hoping this will keep (some) water out rather than a dog in!
Jeremy Westerman
Benicia, CA
Here is a picture of the "Doggie Catcher, it would seem to me you could purchase a piece of Plexiglas for a lot less than $85 plus the cost of a board and screws for the top you already have the sides.
JAS's picture
JAS
It's also good for blocking exhaust from coming into your cockpit at certain wind angles.
Joel Schwartz
s/v Get-A-Grip
1993 Catalina 36 Hull #1259
Newport Beach, California
