Hi, everyone.
I just moved my boat from Atlanta to Fort Lauderdale, and it's on jackstands now for work.
I notice that, when turning the prop by hand, the cutlass bearing is tight and makes a squeaking noise. Is this normal?
I'm guessing that it is coz it's water lubricated and now there is no water in it, right? ...or do I have a new problem?
Ben Ethridge
1984 MK1 Hull# 263
Pour a quart of water o n the shaft while turning it, it should rotate smoothly .
If not, further checking is in order.
Jack F Stewart
1993 C36 #1233 "Windancer"
Port Clinton, OH
Good idea. Thanks, Jack.
Ben Ethridge
1984 MK1 Hull# 263
