Adding water tank under v-berth
James DeBrum
HELLO EVERYONE. MY BOAT IS A 1984. THE SPACE UNDER THE V-BERTH IS CAVERNOUS. I WANT TO ADD AN EXTRA WATER TANK IN THAT SPACE. MY QUESTION IS HOW MUCH WEIGHT CAN I SAFELY ADD UNDER THERE. I HAVE 120 FEET OF CHAIN, 200 FEET OF RHODE PLUS A 30LBS ROCNA  IN THE ANCHOR LOCKER. I KEEP A FEW ITEMS IN STORAGE ON THE FORWARD SHELVE AND AROUND THE GUNNELS. IF ANYONE HAS ANY INFORMATION OR OPINIONS IM ALL EARS.
James DeBrum
S/V Slip Mistress
1984 C36 #333
Charleston S.C.
jgdebrum@gmail.com
Feyerhw
James, our boat is a1990, Mk 1.5. We have 3 water tanks, including one under the v-berth.  I'm pretty sure that it was a factory option, so it's completely feasible.
Bill Feyerherm
"Imagine" 1990 C36 # 1102
Friday Harbor, WA
sidthekid's picture
sidthekid
James, we also have 3 tanks, one in the bow, on a 2002 MKII.
Check out this link from Catalina Direct for more info.
https://www.catalinadirect.com/shop-by-boat/catalina-38/interior/plumbin...
Bill & Barb
s/v Northern Lights
2002 Catalina 36 MKII #2086
Rock Hall, MD
Northern Chesapeake
Rogeragross's picture
Rogeragross
This is an old post so not sure if it's still relevant.
My 1987 C36 has a 20 Gal tank under the V berth which required the sacrifice of two of the three drawers in the forecabin. Not sure if it was a factory option or fitted by a PO. Very professionally done I have to say. However when full of water the bow was very low on the water line and looked unwieldy. With the tank empty it sits much better in the water. I have 180' chain, 180' rode and 30lb anchor. Long story short, I'm about to fit a new 15 gal bladder tank under the aft cabin double berth on the port side just aft of the aqua muffler next to the main 25 gal plastic tank. I'm also fitting an 18" sq inspection hatch to aid access for installation and maintenance. A 1.5" deck filler sits forward of the main tank filler on the port side deck. I also have a 5 gal water container in the aft lazaret, so that takes me back to the 20 gal capacity of the forward tank. I simulated the weight distribution of the new tank using several water filled containers and it does not upset the port-stbd balance.
I'm removing the forward tank this winter and will rebuild the lower two drawers.
Sassenach (Sas-n-ack), 1987 C-36 Mk1 Hull #752, std rig, deep keel
M-25XPB & PRM Newage 125D2 (repowered 2021)
Pender Harbour, BC
