I am trying to locate the windlass switch shown on the schematic for my
1993 MK 1.5. The schematic (Catalina) shows a switch by the circuit breaker, but all I seem to have is the breaker. The windlass worked last fall for the surveyor when I purchased the boat, but I haven't used it since. The battery is at 13.2 volts, but the leads to the foot switch in the anchor locker are really hard to get to. I guess that's the next step if I can't find the disconnect switch.
deltahans
David Hanson
-Watercolor-
1993 C-36 MKI #1244
Stockton CA
Hey David, I've got a 1994 and my circuit breaker -switch for my windlass is located on the forward seat of the stbd settee. But I've always thought the PO wired mine special. I couldn't find it either until I called the PO a couple of weeks after I took the boat home.
There's a switch labeled "windlass on the panel that doesn't do anything.
good luck.
Sam
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
Thanks, Sam
I have the same breaker under the stbd settee, and I also found the (disconnected) light on the panel marked "Windlass"
Hope something turns up...
David
David Hanson
-Watercolor-
1993 C-36 MKI #1244
Stockton CA
