Stay tension
Vic Holland's picture
Vic Holland
Stay tension
While there is a good discussion on tuning the rigging on this website, I have been unable to find a recommended tension (foot/pounds ?) for the stays. My boat was slower on starboard tacks and a buddy with a tension tool found that the tension on the forward starboard stay was half that of the other three. I will retension all the stays once I find the correct setting
Vic Holland
Lepidro #1980
2001 C-36 MK II TR/FK M35B
Ken Juul's picture
Ken Juul
The tension varies with the size of the standing rigging. The actual value isn't that important, what is more important is that they are all about the same. I would start with 15% of breaking strength for your uppers and about 12% for the lowers. Make sure the mast stays in column both port/starbord and fore/aft. Adjust the rear stay, if I remember correctly it is 600# on each leg of the split backstay. Check the mast rake. If too far aft, release some backstay tension, tighten the forestay half a turn, retension the backstay and check the rake again. When you have the fore/aft stays correct, double check that the mast is still in column. Go sail, if the leward shrouds show slack, tighten the shrouds half a turn each and check again. Back at the dock, double check the mast is still in column. Put your cotter pins in and have a beer.
Ken and Vicki Juul
SV Luna Loca
C34 #1090
