Hump hose choices
IslandTime's picture
IslandTime
Hump hose choices
Hi folks, can anyone tell me if this product would work as well as the hump hose being sold on CD?
https://www.amazon.com/HPS-HTSHC-200-L6-BLUE-Silicone-Temperature-Reinforced/dp/B00OUV92JK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1523220336&sr=8-1-fkmr0&keywords=hp+htshc-200-l6-blue
Says it’s rated for 80 psi and 350F.  I believe the one sold on CD is also rated for 350 F.
Thoughts on this half-price alternative?
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
I went with the CD hose.
IslandTime
Leslie- did you look around or just went straight to CD?  Wondering as there seem to be a lot of alternatives out there...
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
I did not look around.  I needed to get running for a trip.
DougS's picture
DougS
I also went the CD route.
Doug Somers
S/V Evenstar #1549
Port: Kingston ON, Home: Ottawa ON
1996 C-36 Mk II Standard Rig M35AC  _____/)___/) /)____
IslandTime
actually I just realized I had spec'ed the wrong size.  Here is the correct one. Need an ID of 1-5/8" since the universal mixing elbow is 1-5/8" OD.
http://www.hps-siliconehoses.com/hps-41mm-reinforced-silicone-hump-coupl...
as you might have guessed I'm rebuilding my exhaust riser, based on the great info from the Reality Check website.
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
