Hi folks, can anyone tell me if this product would work as well as the hump hose being sold on CD?
https://www.amazon.com/HPS-HTSHC-200-L6-BLUE-Silicone-Temperature-Reinforced/dp/B00OUV92JK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1523220336&sr=8-1-fkmr0&keywords=hp+htshc-200-l6-blue(link is external)
Says it’s rated for 80 psi and 350F. I believe the one sold on CD is also rated for 350 F.
Thoughts on this half-price alternative?
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
I went with the CD hose.
Leslie- did you look around or just went straight to CD? Wondering as there seem to be a lot of alternatives out there...
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
I did not look around. I needed to get running for a trip.
I also went the CD route.
Doug Somers
S/V Evenstar #1549
Port: Kingston ON, Home: Ottawa ON
1996 C-36 Mk II Standard Rig M35AC _____/)___/) /)____
actually I just realized I had spec'ed the wrong size. Here is the correct one. Need an ID of 1-5/8" since the universal mixing elbow is 1-5/8" OD.
http://www.hps-siliconehoses.com/hps-41mm-reinforced-silicone-hump-coupl...(link is external)
as you might have guessed I'm rebuilding my exhaust riser, based on the great info from the Reality Check website.
Jeff D
Island Time
'84 MK-I SR/FK #273
Kemah, TX
