Do these windless parts look ok?
Jimmy's picture
Jimmy
I notice some wear but noting looks broke. Please see the enclosed pictures.
Jimmy,
Secondwind
Hull No. 2058
Jimmy,
I can't tell from the pics if there is anything amiss. If you don't see any signs of cracking, which might lead to sudden failure later on, I would reassemble the windlass and judge by how well it works.
There should be no grinding noise from the gearbox. The clutch should engage and disengage smoothly when you tighten/loosen the top nut. The retrieval action should be continuous with no slippage.
Best I can do with advice right now.
Jimmy's picture
Jimmy
Thanks you very much Duane! :)
Jimmy,
Secondwind
Hull No. 2058
