Engine coolant
thisoldfish
Engine coolant
Hi all,
previous owners were using shell extended life antifreeze (red), and though from the 1 post I found on exchanging antifreeze here it seems I should be using Prestone dex cool extended life... that was from 2016.  Curious if anyone has any updates and what folks are using?
also-- my friend who is an auto mechanic mentioned that when he does radiator flushes on cars he just sticks a hose in and runs the engine and lets the hose water flush through for a while.  I know ideally distilled water should be used but curious (since I need to flush the entire system free of the old red stuff) if anyone here does that and if the small amount of residual tap water before refilling with AF is believed to be of sufficient amount to be harmful?
thanks in advance
Brad
S/V Escapade
2003 C36 MK2
Hull 2148
Standard rig/wing keel
Universal 35 BC
Brad, I think it's great that many of us "baby" our diesel engines as it will certainly help to keep them running less problematically over the years.  That being said, they are diesel farm tractor engines modified for marine use.  My buddy has a similar Kubota block engine on his farm tractor and he does not winterize it or change the filters more than once every several years when he happens to remember to do so.  He runs it in the midst of winter with an oil pan heater and it has been working great since 1988.
Myself, I change the air, fuel and oil filters annually, check the transmission fluid level/color, check the fuel/water separator filter, check the belt for wear, check the coolant level and color and the zinc in the heat exchanger.  When it starts to run hot I remove the heat exchanger and soak it in muriatic acid and check for blockages.  Always check the water impeller and carry a spare.  This spring I can see that I need a new gasket under the thermostat housing as it's leaking a bit.
For the coolant I use NAPA diesel premix 50:50, either red/pink or green and drain out the old color if I'm replacing with a different color.  I've never worried about a flush, much less using distilled water.  It's a diesel, a workhorse, not a high octane gas machine.  Doesn't need much babying. I did pull the injectors after 31 years and had them serviced, two were not fully functional.
Biggest learning I had from the minor overhaul last year was that the rocker arm clearances are SUPER important to check under the rocker arm cover. Not a tough or big job, but if they're out by a hair one or more cylinders might be stuck open or closed leading to over heating or mis-firing.
thisoldfish
Thanks for the input.  I have some corrosion in the main coolant reservoir so I'm gonna empty the system, bypass hot water heater and then run some radiator cleaner through and let it sit a while before flushing and then I'll refill with the green Prestone dex cool since that seems to be what's recommended for the older diesels.
But you're right these things are workhorses and not as finicky as gas etc.  it's crazy how little some folks do re maintenance and they just keep chugging
S/V Escapade
2003 C36 MK2
Hull 2148
Universal 35 BC
