1988 Mark 1 - adding bow water tank
Bardo
Hello,
My boat only has a 2 water tanks in back for a total of 42 gallons - 25 main tank under aft berth and 17 in the starboard bench.
I want to add the 24 gallon water tank option to my boat for long distance cruising.
I have spoken with Catalina Direct.  I plan to order the water tank from them.  Catalina Direct tech support was very helpful in explaining the location of the fill and vent in the anchor locker.  I think I am comfortable with this part of the project.
I did my research on the Catalina 36/375 forum here.  I searched for the Mainsheet article.  Unfortunately with Catalina now out of business, there is no more Mainsheet that I could find online.
The part I don't understand is where to drill the holes in the bulkhead between anchor locker and the compartment under the V berth to run the fill hose and vent hose.
Can anyone who has a factory installed 3rd water tank please tell me where the fill hose and vent hose runs through the bulk head?  Major bonus points if you can send a photo of what it looks like in your anchor locker.
Thank you!
Bardo, searching the forum here online should bring up all kinds of posts about the issue.  Has little to do with Mainsheet articles.  Just try a couple of alternative searches.
https://mei1970.org/saillavie/c36Album/index.php?album=Windlass%20And%20...
Bardo, this is the best photo that I have for the v- birth 34 gallon water tank hose connections. The white hose is the water fill that goes up to the deck and just behind it is the vent that is inside the anchor locker.
Feel free to view these photos.  These are photos of installation of wired remote relays for the windlass.
Here is the deck fill
Don't forget : That's adding over 208 lbs. to the bow.
