Hi - Does anyone know if 1986 Catalina 36 has a wood core in the fiberglass or is all fiberglass? I have to remove and replace the chainplates. I'm preparing for the job and would like to know what I'm in for before taking it all apart.
Thnx
Nelson
SF Bay
Chainplates and deck core
Tue, 12/31/2024 - 07:14
#1
Our 1986 C30 had a wood core as does our 2005 C36
2005 C36 MKII #2257
Thanks Paul & Wendy
That's very helpful. I assumed balsa wood core, but great to have a second opinion before disassembling.
Nelson
"Crescendo"
SF Bay
Nelson-
I could not see any wood lamination indicating marine plywood, so I'm pretty certain the decks are cored with balsa. I was impressed with the overall thickness of the deck structure.
Some of the chain plate disassembly/assembly was blind work and required awkward positioning to reach. The most challenging was in the head vanity. The sink bowl restricted wrench handle movement. The bowl was integral to the counter top, so it could not be removed for better access.
2005 C36 MKII #2257
Paul - I know exactly what you describe. Thankfully, most water is around aft chainplates, where there is a little corrosion visible on the underside nuts (so will be the most difficult to disassemble), but that area in the cabin is much more accessible.
Thanks !
I believe, backed up with a pdf cross section diagram I've seen from Catalina sales brochures, that part of the reason that the C36 is well regarded as a "blue water boat" capable of ocean crossings (California ports to Calalina Island) is that the deck has a solid plywood core throughout. I believe there are some hydrophilic fillers that can be injected to reinforce spots that have been waterlogged. A surveyor's moisture meter should allow you to 'map out' any problematic areas.
Here are photos I took in 2014 when I replaced mine. I don't recall if any of that was wood but you can see in the photo there was a sandwich with some gaps in the layers. I injected epoxy to wet it out and then injected increasingly thickened epoxy until I was able to fill the voids.
I also injected epoxy into the bulkhead that the chain plate sits up against - I masked it off so you can't really see it with the chainplate in place.
Steve
1984 Catalina 36 MK I #358
Steve Orosz
s/v RIngle
1985 Catalina 36 Mk I #358
San Francisco Bay
