Standard Horizon old style RAM mic cable issue
TomR's picture
TomR
I'm replacing my NavPod to put in a Garmin 943 chart plotter. But I'd also like to keep my auto pilot & RAM mic connection. The problem I'm facing is that the old style Standard Horizon RAM mic cable has a plastic plate I cannot seem to detach from the metal connector plug inside so I can get the cable through the hole.
Does anyone know how to separate the plug from the plastic plate? Or is it all one molded or glued piece?
pdf Picture attached.
Tom Runiewicz
ObLaDi ObLaDa
Hull #1998
North East, MD
PDF icon RAM Mic Pic#5.pdf1.53 MB
rjwilson's picture
rjwilson
On my 2003 the RAM mic is in the admiral’s panel.  When I replaced the radio, I found cutting the cable and reconnecting it using a terminal board was the easiest way.
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
TomR's picture
TomR
Thank you Bob. Looks like I will have to do the same, but somewhere inside the new NavPod. Any problems with radio interference? Thought the cable was shielded for that and thinking opening it up may cause an issue.
Tom Runiewicz
ObLaDi ObLaDa
Hull #1998
North East, MD
rjwilson's picture
rjwilson
Tom,
I have been using it for several years now and yet to have any issues with it.
Bob
Bob Wilson
S/V Morning Breeze
Williamsburg, VA
