Universal M35 alternator
10 posts / 0 new
EUREKA's picture
EUREKA
Dear all,
Need help, I own Eureka II since new back in 1991, so I know the engine has extremely being well maintained and runs like new al thought it is 31years old.
Alternator was serviced some 10 years ago, but as my intention is to keep the boat, I would like to install a new one. Honestly I do not need to upgrade to a more powerful output, we mainly race the boat and long travels are questions of the pass.
Any body knows the reference and brand of the OE equipment installed on our Universal M35?  I just would like to find almost the same so the replacements goes straight forward with no need of replace cables pulleys, etc...
All the best!
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Home port Barcelona (Spain).
Online
Which engine do you have, M35A or M35B? If you are not sure, post a photo of it.
if the current alternator is the original one  it's part number is printed on a sticker. You will have to remove the alternator to see it.
EUREKA's picture
EUREKA
M35 A,
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
dlincoln3's picture
dlincoln3
If yours is like mine, there is absolutely no identification on the alternator whatsoever.  However, if you have the original 51A alternator, then it is probably a Mando or a Prestolite.  I have service manual info for both that was published for Catalina by Universal, but the file is too large to attach it here.  If you are interested, email me at donlincoln@outlook.com and I will send it to you.
Don Lincoln
"Nancy Lynn"
LaSalle, MI (Lake Erie)
Universal M-35AC
Online
You can download manuals here,  no limit
http://mei1970.org/saillavie/Manuals_C36MKII
EUREKA's picture
EUREKA
Thanks for your help. Mine is the original 51 ah.
Regards
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Online
On page 58 and of the Manual the the part number for the original 51A alternator is listed as 041017.
I had to replace mine as it failed due to replacement of the its broken bracket ( Part No. 200436) as it needed a better grounding. I installed a # 8 ground cable to the shunt near the house battery. The new alternator is painted red instead of the original silver paint.
EUREKA's picture
EUREKA
Looks this part is for the M35B, mine is A. Will be the same alternator?
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
Online
http://www.marinedieseldirect.com/catalogs/catalog_group.php?owner=mdd&p...
42847, this the part number listed for M35A on the above link.
You are correct. It is different.
EDIT. it is not clear to me if this is the bracket or the alternator.
EUREKA's picture
EUREKA
I will have a look.
Eladio Vallina
C-36 TR EUREKA II
Hull 1122 (1991)
