Winterizing macerator pump
dwarren's picture
dwarren
Has anyone tried to winterize macerator pump by using pink antifreeze poured DOWN the waste pump-out deck plate then turning pump on?
Thanks, Dave
Dave & Nancy Warren
"Blue Heron"
Norwalk Cove Marina, CT
2005 C-36 Mk II #2256
'Anniversary Edition'
Wing M35B
rstonge
I use Rich Lemiux's winterization check list.  It includes strps for head and macerator.  It has always worked well for me.
https://www.catalina36.org/members/technical/maintenance/rich-lemieuxs-d...
Ron St. Onge
Make sure the holding tank is empty and then add a gallon of antifreeze through the pump dry setting on toilet and empty the tank again via the macerator pump. Never had an issue in the decades I've used this approach. Simpler than removing hoses.
