Hi,
I have a 1993 Catalina 36 that I purchased in 2017. It came with an Adler Barbour Cold Machine Installed. It has the 101Z Compressor and, I believe, the PB105H evaporator. I am not sure when this unit was installed although I do know it was not initially installed. Currently the freezer temperature only goes into the 25 - 35 degree F range and the refrigerator in the 40's directly adjacent to the freezer and into the low 50's elsewhere.
The location of the compressor is fine, although I am considering improving the air flow. However, it does not get overly warm. The evaporator is mounted on the "shelf" at the aft end of the ice box. I am thinking that I may have 2 problems: 1) Insufficient coolent, and 2) a poorly placed evaporator. Please see the attached image. I am wondering if anyone has a similar configuration, especially the placement of the evaporator and can provide any insight into this situation.
Thanks for any help.
Bob Longo
Raleigh, NC
The condenser placement is like mine. A couple of points. First, make sure the thermostat is free of obstructions and that includes the sensor wires should not tock anything around them. The sealing of the top hatches does effect the efficiency of the unit. I replaced the liners, Catalina Direct has replacements available. The coolant fluid should be checked by a techician. The air gaps around the freezer compartment should be cleared to allow the cold air to sink to the bottom of the fridge. Lastly, the thermostat control could be defective. It is best to have a technician look the unit over.
Lou Bruska
Sojourn
1986 C-36 Mk 1, 495
Lou Bruska
Sojourn
1985 C-36 Mk-I TR #495
Eldean Shipyard
Rallyback@comcast.net
My freezer temperatures are normally in the mid to high teens and the refrigerator in the low 40s. The setup is the same as yours which I believe is standard from the factory. When I bought my boat the refrigerator had trouble getting the temperatures to where they needed to be. I recharged the system with a can of refrigerant from the auto store. You will need an adapter (check Wal-Mart) to connect the system to the standard fitting used for cars on the can.
Bob Wilson
S/V Morning Breeze
2003 Catalina 36, Hull 2122
York River Yacht Club
Williamsburg, VA
Bob and Lou,
Thanks so much for this information. I am reassured that the configuration does work if all is well with the system. I will check the items you have suggested. Great Info. Thanks again!
Bob
Bob Longo
Raleigh, NC
David S. Power
Two If By Sea #1687
Burnt Store Marina
Our 1991 MK 1.5 has the same configuration. I replaced the control module (?) with heat sink with one of the last ones available from Holland Marine last year and saw a reduction in the constant cycling on-off, but it still underperforms on days over 75 degrees farenheit. I may look into the self-recharge another member mentioned with an auto cannister and adapter. Eventually we'll have to drop the big bucks and put in a cold plate to replace the old box.
David Power, I'm curious why you suggest lining the INSIDE with an additional layer of foam, given the loss in volume inside, plus the less than appealing esthetics of doing so? I'm looking at spray foaming the outer walls of the box below the counter, plus maybe some foam board on the aft side as Julandra's owner has done. Yes, it might miss some warm spots, but surely a thick additional outer shell will accomplish CLOSE to what you'd get with inside lining, but without losing the waterproof fiberglass interior?
I'm also looking at the idea of adding a fan inside, although convection SHOULD mean that the cold air all sinks and leaving the most vulnerable goods at the bottom/back and fruits/vegetalbes on the upper shelf works almost as well?
I do have the impression that the hot space in the port side lazerette makes the unit work too hard, but perhaps high temperatures around the compressor and control panel do not effect performance?
David S. Power
Two If By Sea #1687
Burnt Store Marina
Thanks for that, David. A photo of your fridge interior would be helpful if you can manage it someday. Would like to see how you finished the corners and worked around the ice box and controls.
On Julandra (see photo) the owner added a panel of what looks like 7/8" foam board in the rear area through the aft cabin sliding panel (a challenge) and I believe got into the front space by removing the cubby under the stove and used a long flex tube to spray up under the counter, but drilling holes through the inner wall of the fridge would also work, then seal the holes. Still, to your point, not as guaranteed to ensure full coverage as doing the interior.
On a lovely C36 out of NY whose name I cannot recall the owner installed a cold plate that solved most issues merely by being so damn cold! Not sure what the draw is compared to the old Alder Barbour units, though.
Thanks for all the input.
I defrosted the fridge, made sure that nothing gets put around the freezer unit and installed 2 fans inthe fridge to circulate the air better (see attachment). The inside of the freezer unit is consistently between -5 and -10 degrees F. Just outside the freezer the temperature is in the mid-40s and elsewhere still in the high 40's to mid-50's F. This is with the thermostat on its lowest setting of 7. This situation is consistent with the fridge empty or with food in it.
Since the freezer is below 0 degrees F it seems to me that a problem with the thermostat is unlikely since it takes it reading from the freezer unit. That would seem to leave a compressor/condenser problem - most likely low refrigerant.
Does anybody have any insight to share on this? Also, for those who have a well functioning unit, what thermostat setting works well for you?
Bob
Bob Longo
Raleigh, NC
David S. Power
Two If By Sea #1687
Burnt Store Marina
Thanks for the photo and good job, David. I only wish I could get our old unit to perform anywhere close to that. When the outside temperature is cold it freezes, but once it is warm, even with the new controller, it not only cannot freeze, it drains the batteries even with the original equipment old charger running non-stop plugged in to shore power.
I haven't tried refilling the refrigerant, but it is certainly filled with the old stuff and I am certain I need to empty the old stuff out in order to refill it?
David S. Power
Two If By Sea #1687
Burnt Store Marina
If you are not aware here is a good source for information http://kollmann-marine.com/
I replaced compressor and evaporator approx. 5 years ago worked pretty good 1st year but diminished by 2nd
Check wiring I replaced my wiring with #8AWG when i realized the distance. That helped with cycling.
I believe you figured out you can't mix refridgerants old vs. new
Kollman's 12 & 24 V book helped me with recharging which I did 3 years ago Icebox now about 40 degrees after 6-8 hours
Small two battery fan moves air and circulates.
Freezer freezes everything
Aldor Barbour unit says approx 4-5 amp draw in manual.
My unit cycles on for about 5-6 mins, than off for about 10 minutes originally 4 amps now upto 4.5 amps. It is possible I need to recharge but with 4 cycles per hour the draw is draw around 1.5- 2.0 amps per hour.
I have a Ganz 80 watt panel that produces about 1-2 amps per hour which helps offset the refrideration while sitting on mooring
Just some random thoughts from my experience but Kollman is a good source!
This week my frig unit was replaced on my 2003 C36 #2164. The refrigerant was leaking at a pin-hole point where the tubing goes thru the box wall. As I understand, the tubing corrodes there at the caulked opening. I’d had the Freon (?) recharged twice over the last two years, success at first, then returned to never getting colder that 50°F (and never cycling, running all the time.
Replaced with a Nova Kool unit.
Steven Jones
C36/375IA FaceBook group administrator
Seal Beach, CA, USA
C36 #2164 Maléna 2003 Mk-II SRig/FullK, Long Beach, CA
stevenjones21@gmail.com
David S. Power
Two If By Sea #1687
Burnt Store Marina
Steve,
Thanks for the input. I have a tech coming to look at my unit this week. This sounds like it could well be the problem. I'll post once I know the resolution.
Bob Longo
Raleigh, NC
