Need to Replace Fresh Water Pump
kenstrom
I have a ShurFlo 2088-723-244 fresh water pump, likely the original equipment.  It has trouble now and then, but taking it apart and putting it back togetehr seemed to fix it a couple of times.  I think I need to carry a spare or replace it, or at least have an overhaul kit.  I see Tom Soko recommended a different style pump -- 4901-0211 back in 2015, but that pump is not available.
Any suggestions on a replacement pump, on an overhaul kit would be appreciated.  Would like to have the same physical size and mounting to simplify replacement, but would modify mounting and plumbing if I had to or there was an advantage to a newer style.
Ken Enstrom
2004 C-36 MKII #2199
Tall Rig, Wing Keel, M-35B
two-rocks
Just replaced my old sureflo variable speed pump. It would run at a very slow speed, with no call for water.
I like the variable speed, and went with a Marco UP2/E. Very little use at this point, but seems live a really nice pump. Fisherias supply sells them, but it was $70 les to get it from Italy, including 2-day DHL. The pump in tiny, and has a brain with lots of LED's to indicate what it's doing.
Ken;
Might start looking here;
http://c34.org/bbs/index.php?topic=5133.0
Ken;
 I was down at the boat today and found that I replaced our fresh water pump with a Flo-Jet, Model # 4405-143. It delivers 4.2 gpm at 35 psi. and is designed for the marine enviorment.  It drives the sinks and showers just perfectly and it does not require a accumulator-pressure tank since it is a four lung unit. . Don't forget to order the elbows if necessary for your installation however the unit below comes with right angle connectors.
https://www.amazon.com/Flojet-04405143A-System-Bypass-Included/dp/B000O89F36/ref=sr_1_2?keywords=flojet%2B4405-143&qid=1558923239&s=gateway&sr=8-2-spell&th=1&psc=1
sidthekid's picture
sidthekid
We had a Jabsco 3.5 GPM 40 PSI installed in July 2018. Similiar specs to previous pump. Works fine so far...
Bill & Barb
s/v Northern Lights
2002 Catalina 36 MKII #2086
Rock Hall, MD
Northern Chesapeake
