holding tank vent
Siler Starum's picture
Siler Starum
holding tank vent
Does anybody know if there is a filter / mesh in the stanchion part of the holding tank vent?
Durk Nijdam
S/V "SILER"
Stavoren - Holland
William Matley's picture
William Matley
My boat waste tank vents directly to the stanchion base with nothing filtering or impeding the air flow.
Bill Matley
Cheboygan, Michigan
Lakes Huron, Michigan,
Canadian North Channel
"Spirit of Aloha" Hull #1252
Siler Starum
I was afraid that maybe a hidden mesh was fitted in the stanchion blocking the vent of the tank but, my "black-water system problem" is luckely not caused by a blocked vent. In my perspective the vent-line is too small. Normally I would expect a vent to be at least the same diameter as the filling line. With overhauled toilet pump and with closed overboard valve it is an easy job to let the waste-tank look like a balloon...and when pumping out the head is a perfect vent...
Durk Nijdam
S/V "SILER"
Stavoren - Holland
Durk-
I think there's a fair amount of discussion on this site regarding holding tank venting and the consensus is that a larger vent would be a good idea to better support the bacteria in breaking waste down. Search, and I think you'll find postings on adding 2nd vent on the opposite side of the boat or expaning the size of a single vent.
Parsons's picture
Parsons
There is no filter or mesh in the standard Catalina stanchion vent.  That said, the hole or slit in the stanchion is very small, and unnaturally attractive to spiders, so you may have 'all natural, organic' mesh in there now!  I suggest using a garden hose each time during your pump out cycle.  Many of us have replaced the hated stanchion vent with a standard mushroom vent drilled through the hull below the rub rail, just below the stanchion.  The hose size is 5/8", I believe, and after changing to a mushroom fitting is not too small.  Many photos on this site, and other sailing sites like Sailboat Owners. Here's the inside of mine.
John Parsons
Tall Rig, Fin Keel
Bay City, MI, USA
