Looking at a Catalina Mk1
9 posts / 0 new
Paul Revere
Hello everyone
Looking at picking up a 87' 36 and had a few questions.
-It's a wing keel. but I've seen various numbers on that draft.anywhere from 4'1 to 4'5 anyone know for sure?
-Does anyone have a list of options the factory provided? This boat seems to have a lot of stuff(Interior and exterior)I haven't seen on other 36s, i wanted to see what came with it new and what was added on at some point in her life.
-There are 2 rows of what look like snaps inboard of the grab rails on the coach roof that I've seen on other 36s too. anyone have any idea what their for?
-Tank sizes. brochure says 33g for fuel and 72 for water. are those standard or was that fully optioned? any way to tell what it has? I've seen a myriad of different numbers.
-Any general problems to look for?
-Boat was struck by lighting but fully repaired. anyone have any cat 36 specific related issues if this has occurred to them?
Paul
Paul;
 Welcome to the forum and good luck on your search for a Catalina 36. Certainly in the thirty six years since the boat was built, you can expect that a number of things have been replaced with new gear and the boat has changed.
First, let me answer you specific questions: Draft; Figure that the design spec's called for a draft of 4 feet 2 inches empty in salt water but that was a desgn spec and does not accuratly reflect what the final draft of the boat will be.  By the time you add the weight of 42 gallons of water @8.35 pounds per gallon and 30 gallons of diesel @7.3 pounds per gallon , plus all the pots pans, radios, and many pounds of misc. personal stuff, you be lucky to make the 4.5 foot draft ! Figure on a slightly less than 5 foot draft. Measure & weigh it during haul out survey. Many marine travel lifts have a built weight scale.
How much water ? Spec's on your 1988 boat called for 42 gallons. Originally there were two tanks in the aft cabin. One in the center line and one on the starboard side. The owner may have added a bow tank (not original equipment) at an additional 24 gallons.
Fuel; Many of the fuel tanks in that aged boat have been changed out. The new tanks are just slightly smaller to accomidate refitting in to the boat. The standard refitted tank is about 30 gallons with perhaps 27 gallons useable. (You never want the fuel to get down that low in a diesel tank anyway) There may be a plate on the tank specifing the capacity.
On the dual buttons on the rail, there are several different style covers that fit over the teak rails, some that just fit over the teak cabin top rails and some that fit over the rails and the window. (Picture below)
What to check ? Everything ! Have a good survey of the boat (You'll need it for insurance anyway) Rudder, engine, etc. Figure you'll put 10% of the purchase price of the boat fixing her up to get what you want.
It might be an idea to mention your location and we'll know what types of conditions you're sailing in.
Search the forum/technical library here for the manual that came with your 1988 boat. Don't be afraid to ask questions here. We've all been where you are.
You might some valuble pre-buy information in these articles by David Pasco; https://www.yachtsurvey.com/
Image icon IMG_2077 (Small).JPG103.45 KB
Paul Revere
thanks for all the info! she will be sailing in south Florida waters and offshore in the Caribbean. she is a tall mast. with regard to the water, is it possible that there are two optional 36 gallon tanks instead of 2 21 gallon tanks? I am asking because I have seen brochure specs stating 72 gallons on the 1987 C36.
attached is a picture of what appears to be A/C... is this correct or is this part of the refrigerator system?
Paul,
Quite possible I have that quanity wrong and yes it is possible, although I do not think there were optional tanks offered. Perhaps someone here on the Forum has a 1988 and the correct answer as to total capacity. . Did you research the tech section for the manual/spec sheet ? It also may be that the two tanks hold different quanities of water.
That refrigirant tank you pictured is filled with type 134a refrigerant and is probably for the refrig. If the boat had air conditioning there would be cold air vents located through out the boat.
Paul Revere
Thanks for the help! I ended up purchaseing her today!
Hull # CTYR0990D987
Congradulations Paul !
How is she equipped ? Just curious as to your location ?
Paul Revere
She is fairly well equipped.
Tall rig with wing keel.
Has brand new raymarine autopilot,wind index,depth,speed,radar, and chart plotter that all communicate with each other. 2 VHFs, Sound system.
Main,Jib,spinnaker
windlass, lazyjacks,dodger,bimini,davits, 16,000 BTU A/C system.
she was in the NC rivers and coast for the last 10 years. And will be heading to south Florida and the carribian. so few upgrades such as solar,water capacity, new windlass etc are coming down the line.
dlincoln3's picture
dlincoln3
Congrats on buying a great boat!  Mine is a '93, and it did come from the factory with 3 water tanks holding 80-ish gallons of water total.  At some point, Catalina added a 3rd water tank under the v-berth for the extra capacity.  My boat was also hit by lightning in 2014 (before I purchased it) and partially sank when the strike blew out the depth transducer.  Of course, all of the electronics, charger, and batteries had to be replaced, and it sounds like your electronics have already been done.  I also had to replace the water heater element, and the GFCI AC outlet at the chart table.  There are some devices that were ruined by the strike that I haven't replaced yet, such as the battery monitor and the AutoMAC alternator regulator.  Otherwise, everything else was OK.
Don Lincoln
"Nancy Lynn"
LaSalle, MI (Lake Erie)
Universal M-35AC
Phil L's picture
Phil L
I have had my '85 since 2005, and she has brought me much joy over the years.  Stay on top of the required engine maintenance, and she will give you years of happiness.
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
