We could use a little help in selecting the model or correct part number of the K&N air filter that works/fits on the M-35 Universal Engine. If anyone has that part number, it would certainly help.
Hi Bill-
If all else fails, call a Universal Engine dealer. I use Hanson Marine in Marblehead MA; 781-631-3282. They ship across the US. My aircleaner housing on my M25 (C-30) broke apart from vibration and they directed me to an improved design.
2005 C36 MKII #2257
https://www.knfilters.com/universal/universal.htm
K&N RU-2450
Ken Akers
1995 C-36 MkII #1378 SR/FK M35A
San Francisco Bay
I used: RU-0360
I little longer than what was posted with more surface area. I think it was cheaper as well.
The specs for all the filters are on the K&N website, you are looking for a 1.75" connection - the other dimensions are flexible to a point.
Query for those of you who have installed the K&N as a replacement for the OEM "pancake" style Universal air filter:
What do you do with the crankcase vent hose (on our M25, its routed into the air filter)?
Paul, Ken & Greg;
Just a short note to say' thank you' for passing along that information regarding the part number of the filter. The folks at the 'K&N help line' tried their best but came up empty.,,,
Bill,
From Rod Collins aka Mainesail: http://www.pbase.com/mainecruising/m25_air_filter__pcv_valve
Second picture shows routing the PCV hose into the filter.
Ken Akers
San Francisco Bay
Follow up;
After consideration, I decided to go with the K&N RU2450 and side mount it on the side of the of the M-35 engine. The intake air manifold on the M-35 engine is not quite the same as the M-35 A & B engines. Although the air intake is the same diameter, (1.75) - the manifold input port on the M-35 runs parallel with the floor - where in the later model engines, the input port has an elbow and points skyward.
I do not intend to run the oil breather exhaust hose in to this filter, rather, I will take the oil breather hose and push it into an empty water bottle with some stainless steel wool at the bottom of the bottle. Not pretty but effective.
I use the 2450 as well. And I plumbed the breather tube back inot the filter to keep it from getting too oily. Works like a charm.
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
Thanks for the picture Phil. I think I'll give that a try.
