K&N Air Filters - Part # ??
10 posts / 0 new
We could use a little help in selecting the model or correct part number of  the K&N air filter that works/fits on the M-35 Universal Engine. If anyone has that part number, it would certainly help.
Hi Bill-
If all else fails, call a Universal Engine dealer. I use Hanson Marine in Marblehead MA; 781-631-3282. They ship across the US. My aircleaner housing on my M25 (C-30) broke apart from vibration and they directed me to an improved design.
kakers
Ken Akers
San Francisco Bay
two-rocks
I used: RU-0360
I little longer than what was posted with more surface area. I think it was cheaper as well.
The specs for all the filters are on the K&N website, you are looking for a 1.75" connection - the other dimensions are flexible to a point.
Query for those of you who have installed the K&N as a replacement for the OEM "pancake" style Universal air filter:
What do you do with the crankcase vent hose (on our M25, its routed into the air filter)?
Paul, Ken & Greg;
Just a short note to say' thank you' for passing along that information regarding the part number of the filter. The folks at the 'K&N help line' tried their best but came up empty.,,,
kakers
Bill,
From Rod Collins aka Mainesail:  ​http://www.pbase.com/mainecruising/m25_air_filter__pcv_valve
Second picture shows routing the PCV hose into the filter.
Ken Akers
San Francisco Bay
Follow up;
After consideration, I decided to go with the K&N  RU2450 and side mount it on the side of the of the M-35 engine. The intake air manifold on the M-35 engine is not quite the same as the  M-35 A & B engines. Although the air intake is the same diameter, (1.75) - the manifold input port on the M-35 runs parallel with the floor - where in the later model engines, the input port has an elbow and points skyward.
I do not intend to run the oil breather exhaust hose in to this filter, rather, I will take the oil breather hose and push it into an empty water bottle with some stainless steel wool at the bottom of the bottle. Not pretty but effective.
Phil L's picture
Phil L
I use the 2450 as well.  And I plumbed the breather tube back inot the filter to keep it from getting too oily.  Works like a charm.
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
Thanks for the picture Phil. I think I'll give that a try.
