Electrical Wiring
Talisman
Electrical Wiring
So I have had two separate positive (red) wires feeding current to my multi-display and another to the pilot computer fail this week. Is there a ”vintage” problem to my 1998 MK2 36 wiring and or electrical systems that I don’t know about?
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
True Wind
Talisman
What do you mean by fail?
2003 Catalina 36
Non tinned wire goes black in a couple seasons unless sealed.  Personally I’d cut off the connector rub the Black off and try a new connector before pulling new wire.
Les
danno
You can also, after cutting back as Leslie suggests, use a proper rosin core solder to tin the end of the wire  then re-terminate to prevent further oxidation issues.  The flux will help clean the wire further and the solder seals the copper from the atmosphere.  Any time you replace wire though, do make sure you're using the appropriate marine grade wire.  Also verify your wire sizing is correct, by modern standards and with the addition of owner installed components we found much of our original wiring to be undersized.
Dan & Amanda Reed
Fin Keel Std Rig
FL Panhandle
