Stop Screeching Companion Way Hatch
mholzmann's picture
mholzmann
 Screeching Companion Way Hatch?  Many years back Graham Mackay posted a solution to a screeching companionway hatch sliding against the cabin top.  I followed his instructions to the letter and it solved my problem.
New problem is I needed to buy a huge sheet of plastic 48" x 92" to get (2) 1"x 72" x 1/16.  So needless to say I have the ability to make a lot of strips.  If you have a screeching hatch  $15.00 paid to paypal will deliver a set of pre cut strips to your door.  These really work they install in minutes with no removal or alteration to the hatch assembly.  You won't find a cheaper way to obtain this material unless you get lucky in the left over material pile, LOL  Please include your mailing address and email address.  www.paypal.me/markholzmann/15
Mark Holzmann
"Hawkwind"
Sail #1246
dwarren's picture
dwarren
Another attempt.....
Dave & Nancy Warren
"Blue Heron"
Norwalk Cove Marina, CT
2005 C-36 Mk II #2256
'Anniversary Edition'
Wing M35B
mholzmann's picture
mholzmann
The strips work fantastic on pre 1995 C36 Mk 1.  The Mk II has a different hatch configuration and the screeching is at the top rail versus the bottom of the channel.
Just reordered a new batch for the Mk I owners!!
Mark Holzmann
"Hawkwind"
Sail #1246
Mark;
 Those strips work great on Hull #1041. I had to put a small strip of double sided tape to hold them in place as they as so slippery.
mholzmann's picture
mholzmann
Great to hear all the rave reviews!  Its too funny that such a simple solution works.  I have used a small piece of rubber butyl tape atthe end near the hatch boards with great success.   I just reordered a bunch of strips and have about 15 sets on hand.
Mark Holzmann
"Hawkwind"
Sail #1246
Phil L's picture
Phil L
Another thumbs up on these.  The only problem now is I need to remember they are there.  The hatch slides open so easily now I tend to slam it open.
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
mholzmann's picture
mholzmann
Thanks Phil for the kudos!!
Mark Holzmann
"Hawkwind"
Sail #1246
