Replacing the fixed portlights
dlincoln3's picture
dlincoln3
Just an FYI.  When I purchased my boat last year, two of the large fixed acrylic portlights were cracked.  No idea how that could have happened.  Anyway, I replaced them this past winter, and I finally got around to writing up how to do this.  The new ones look fantastic.  It wasn't much fun to do, but if you need to do it see the attached.  -Don
Don Lincoln
"Nancy Lynn"
LaSalle, MI (Lake Erie)
Universal M-35AC
File Replacing fixed ports1.02 MB
Great information Don! Thanks for documenting and sharing it!
kenstrom
Great write-up.  I'm tucking this one away for future use.  Notes like this makes it so much easier to tackle a job.
Ken Enstrom
2004 C-36 MKII #2199
Tall Rig, Wing Keel, M-35B
Alain Croteau's picture
Alain Croteau
Great write-up and result. Just wanted to suggest that using a multi-tool with scraper blade attachment to remove old adhesive followed with the sanding attachment works very well and quickly.  No need for adhesive remover.  Did all 4 portlights this spring.  I used Boatlife Life-seal adhesive which was a bit messy but solid result. Sounds like the two sided tape is a more ideal method with no need to mask the inside edges of openings. One question: are you planning on using the two sided tape to the wide surface between the main cabin and aft cabin?
Alain Croteau
"Veritas"
C36 #1226 SR/wk
Yanmar 3JH2
Kingston, Ontario
dlincoln3's picture
dlincoln3
Yes I think so.  It seems like it would make sense to do so, but I'll see what was done originally when I take the old ones off and I'll probably copy what the factory did.  If they applied sealant to that section, then I'll do the same with the tape.
Don Lincoln
"Nancy Lynn"
Universal M-35AC
