transmission control cable shift bracket
ludo's picture
ludo
Hi!
As you can see in the pictures below, the bracket maintaining the control cable is totally oxide. What do you advise? Should I replace it, where to buy a new one?
Ludovic François
Marina Del Rey, CA
I would just take a wire brush/wheel and clean it up. Get a good primer and paint and repaint it. Do not believe it has a heavy load on it, so it should be fine.
