My engine has net to 1800 hours.
should I carry a fuel pump as a spare on board? I do coastal cruising.
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
Theme by Zymphonies
I have a extra ,its cheap and if it goes out so does your engine
It is cheap insurance but my engine ran fine without the pump operational. Realized it was bad only after the engine cover was removed to do an inspection. Not sure how long it had been out prior to that. Could have been since the last filter change. The tank is mounted higher than engine though
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
M35A Oberdorfer conversion
David S. Power
Two If By Sea #1687
Burnt Store Marina
