OEM fresh water pump for 2003 C36 MKII?
ashiff
Hi,
This is my first post.  Anyone know what the original OEM fresh water pump was for a 2003 C36 MK II?  Pretty sure it's a ShurFlo pump but not sure of GPM or model.  I'm away from my boat (and paperwork)  and it would be great if I could stop at West Marine on my way down to the boat to get the correct rebuilding kit before going out to my mooring.
Andrew
Kayla III
C36 MK II
#1444
West Falmouth, MA
jwilson
Andrew:
My C36 is a 2003 as well that I just purchased last year.  Not sure if it is original but my fresh water pump is a Shurflo 3901-0216.  Picture attached (I hope).
Jeff Wilson
jeffwlsn39@gmail.com
Jeff Wilson
BoyNSea
​2003 Catalina 36  Hull # 2159
New Castle, NH
ashiff
Thanks Jeff,
Much appreciated!  Got the picture.  Sailed the last 2 day w/ company so no work time.  Calling W. Marine now and heading out to the boat.  Even if there's no kit available now, maybe I can clear out the screen, hopefully.  Have a great season on your new boat!
We love ours.
Andrew
Andrew... I replaced my pump with a higher pressure pump if your so inclined. However, if you have heat/AC under the salon seat in front of the galley, it wont fit in the old spot and you'd have to remount it. .... FYI
ashiff
Thanks, Chuck.
I took off the filter (Shurflo #170) and saw about 1/8" of black guck in the bowl and the screen.  Looked like it was  'glued in' but my wife said give me a pencil with an eraser, and proceeded to push the fine screen right out.  I cleaned it, and now we're getting close to 3 GPMs.  Enough for us now.  It's a 2003 C 36 MK II and I have no reason to think the pump isn't original, so I'll use it till it gives up the ghost.  Next one will be a higher pressure pump.
