Edson Steering Failure info post from Catalina Direct
http://catalinadirect.com/index.cfm/product/2614/pedestal-steering-cross...
This is interesting info that I just received from Catalina Direct- involving steering system failures from corrosion of pulley mounts - applicable to 2004 and earlier models.
osprey's picture
osprey
Has anyone experienced failure of this part.  I looked at mine; it has some corrosion but I can't tell if it is serious.
Ed S.
Osprey
1988 mk I, # 845
Ventura, Ca.
scozzer
Checked mine:   Some minor superficial rust easily removed with a wire brush.  Then touched the rust spots with phosphoric acid; wiped it dry.   Finished with a smear of lanolin protective "wax"
Now looks like new ..   well almost.
Philip Schofield
Ventura Yacht Club, CA.
Tommy T
Hull 572
