Fuel tank sending unit
rtrinkle's picture
rtrinkle
Hello all.  Looking to validate something on my 1995 c36 mk ii, hull 1433. I've read some articles on the sending unit. I have a aluminum tank. I have noticed the access port for the fuel shut off valve, but never noticed one for the sending unit. If I have to cut a hole and install an access port, what would be a good size to get?  Also, where would the sending unit be. mounted?
Also, want to validate the tank size if I need a new sending unit.  The sending units on catalina direct shows one for a 25 gal and another for a 19 gal tank. Everything I have read says it's a 22 gal tank.
My gauge has been having problems. First, the gauge went far left when the tank is full. Once it dropped to about 3/4, it would read correctly. Now it's not reading any fuel level. When I turn the key on, the gauge moves far left. When I turn the key off, the gauge relaxes back to its resting position, a few mm to the right of "e". So I can actually see the gauge ping hard left when I turn the key on.
I want to troubleshoot this weekend. So if I need to install an access port, I want to get it before I go to the boat.
Thanks for for all your help in the past and future.
Robert Trinkle
Universal M35A
Kinsale Harbor Marina
Kinsale, VA
kakers
My fuel gauge has stopped working, too.  I went through the troubleshooting procedures and determined that the sending unit is bad.  Like your boat (ours are only a few hull numbers apart) mine only has the one access port for the fuel shutoff.  It's a standard 4" Beckson screw out deck plate.
I bought a second one and plan to install it over the sending unit.  Requires a 4.5" cut-out which I plan on doing with a hole saw - very carefully!
My boat has a 25 gal. tank.  Looks just like this one from Catalina Direct:
http://www.catalinadirect.com/index.cfm/product/2314_800/fuel-tank-25-ga...
Ken Akers
San Francisco Bay
rtrinkle's picture
rtrinkle
That's what I thought.  Thanks for the info.  Guess its another trip to West Marine for the deck plate.
Robert Trinkle
Universal M35A
Kinsale, VA
I recently located that problem. It is the sending unit. On mine you can remove the sending unit by removing 5 screws from the top of the fuel tank. It had loose connections inside. You can replace this unit for about $ 30.00. Defender has it  see link below.
http://search.defender.com/?expression=fuel%20sending%20unit&s=1
There are several lengths - on my tank it was 12" arm.
rtrinkle's picture
rtrinkle
Thought I would reply again with the schematics of the fuel tank.  Good info to have.  Got this from Catalina Direct.  This is the steel, 25 Gal tank.
Robert Trinkle
Universal M35A
Kinsale, VA
PDF icon c-34-c-36-fuel-tank-drawing-a8248.pdf275.45 KB
