exhaust leak?
Talisman
exhaust leak?
I noticed a small amount of smoke, like a wisp, comes out of my running engine between the Exhaust manifold and elbow.  I tightened the clamp but it didn't help. Is there a gasket or something in this junction that needs replacing?
Enrique
Talisman
1998 36 MK2 Hull #1673
Tall Rig Wing Keel
M35BC engine
Old Saybrook, CT Summer
South Glastonbury, CT Winter
knotdoneyet
There is a gasket between the two that makes the seal when the V-Clamp is tightened.  Not this first place I would guess it would leak   Are you sure it's not leaking from the exhaust riser itself and just leaking out the end of the heat wrap.  It is most likely your exhaust riser is corroded.
I just replaced my exhaust riser with one from Catalina Direct and it fit perfectly.  I suggest ordering a new exhaust flange as I couldn't remove mine from the old riser.
2000 C36 MKII 1825
Talisman
Thanks for the reply.
Just replaced mine 3 seasons ago but I don't think I replaced the gasket.  What flange do you mean?
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
Talisman
Are you talking about the exhaust elbow clamp?
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
knotdoneyet
Here's a link to the exhaust flange but you would only need it if you are replacing the whole exhaust riser.  Not sure what type of exhaust riser you went with but some of the DIY's can fail in as little as a year depending on the pipe used.  The one I replaced is stainless and clearly the original from the factory.  So roughly 14 years on it.
Engine Exhaust Flange Circular, "B" Series Engine
Engine Exhaust FlangeCircular Gasket Only
2000 C36 MKII 1825
Talisman
Thanks.
i got the stainless one directly from Catalina so hopefully will be ok.  I'll replace the gasket and the clamp to be on the safe side and see how that works out.
Enrique
Talisman
Tall Rig Wing Keel
M35BC engine
