I'm gonna take a shot at changing fluids on my boat. Last time it was done by a professional in about an hour for around $500 i think.
I'm gonna look at my owner's manuals, and here, and i should be able to get enough information to do this myself.
Not sure what needs to be done, but at the very least, engine and tranny oil, and fuel filter.
I was thinking about buying one of those electric powered oil removing pump set ups. I saw one from West Marine on Craigslist for around $70.
What do most people use to suck the oil out?
Blair White
2004 C36 MKII # 2169 "Dash"
Pacific Beach, CA
Hi Blair,
Someone with an M35 will no doubt chime in, but on the M25 (in the older boats) the oil pan drain plug is accessible under the engine and you can just drain the oil into a trash bag. You can never get all the nasty dirty stuff at the bottom of the engine with a pump.
If you do use a pump make sure the engine is good and warm to thin the oil.
Many of the mechanics I see use hand pumps for small engines, maybe no need to buy a powered one.
[Also wanted to explain that posts are still delayed, legacy of the Summer of Spam. Sorry for the inconvenience, we should have that restriction lifted soon.]
Nick
Nick Tonkin
Hi
I work at West Marine. Be wary of the pumps which are built into the lid of what looks like a plastic bucket. They are unstable when empty due to the offset weight of the electric pump from the center line of the bucket...ie it falls over unless full. Not much good when you are beginning the pump out process.
Duncan McNeill
1984 Catalina 36 #178
standard rig fin keel M25
Channel Islands
Well, you should go from $500 to $30. It takes all of 30 minutes. I use a gallon of 15W40 Rotella, a Fram PH-3593-A, and a $6 (Harbor Freight 66418) hand pump connected to the drain hose. After warming the engine and removing the threaded cap from the drain hose, I insert the drain hose directly into the intake port of the pump and stick the output port of the pump into the top of a 1-gallon jug. After all the oil is out, I take a plastic trash bag and drop the pump into it, remove the drain hose from the pump, and reinstall the threaded cap onto the drain hose. You can either throw away the pump or take it home and stick it in the sink and pump some warm water and dishwashing liquid through it.
Next you would change the spin-on oil filter. Usually a bit more of a mess. Invest in an oil filter band-type wrench for small filters (such as: http://www.awdirect.com/swivel-oil-filter-wrench-for-2-7-8-to-3-1-4-dia-...). This same filter wrench also fits the spin-on fuel filter. Place lots of paper towels or a Pamper under the filter and have a plastic trash bag ready. After loosing with the wrench enough to hand turn, you can minimize the mess by placing a large freezer bag around the filter so that it extends as much as possible over the bottom portion of the filter mating flange. After unscrewing, try to keep the threaded end "up" as much as possible as the filter will still contain some oil. Clean the flange, apply a bit of clean oil to the new filter gasket, and then spin-on. Hand tighten only!
Using a funnel, pour the gallon of oil in, crank up and run for a minute, shut down and check for leaks and your dipstick level. Here's a good link:
https://www.catalina36.org/members/technical/maintenance/oil-and-filter-...
[quote=ScottishDuncan]Hi
I work at West Marine. Be wary of the pumps which are built into the lid of what looks like a plastic bucket. They are unstable when empty due to the offset weight of the electric pump from the center line of the bucket...ie it falls over unless full. Not much good when you are beginning the pump out process.[/quote]
Not to go off topic, but Duncan, do you work at the WM on Channel Islands Blvd,? I was just there last week (and am there WAY too often). I'll look for you next time I'm in. Having a fellow C36er at WM may help in knowing what to use and what not to!
Phil L
Southern Cross
Channel Islands, CA
C36MKI #400
Re Duncan's comment about the pump/bucket being unstable, he's right. What I do is keep the bucket in a box I saved from 6 gals of anti-freeze when I winterized whenever I use and store the pump. This keeps it stable and I have enough room to keep a sheet, for under everything when I work, a small 1 gal fuel container (may be a 2 gal) to fill with fuel to refill the filters and a plastic nozzle I screw onto the oil bottles to prevent spillage all in one place. Works fine and I prefer that to the flat model with the pickup tube in clips around the tank. The clips never hold the tube correctly ( have both).
When changing the filters don't forget the water separator filter oo.
These guys have pretty well covered it, but here's a tip.
While you're messing with the oil change, use your pump to suck out the ATF from your transmission fill-and-check opening on top of the tranny. I think the dipstick bolt head uses a 17mm wrench.
On my 1986 model C36, the Universal M25 is mated to the Hurth HPW50
with a capacity of 0.3 ltrs. of ATF transmission fluid.
Be aware that you check the fluid level WITHOUT screwing in the dipstick.
I'll include a pic of the pump I use: Jabsco Flat Tank Oil Changer System, Model# 17860-1012
Good luck!
Mitch
1986 Catalina 36 MKI
S/V "Blessing"
Kema, TX
Hull: #584
M25 w/ Oberdorfer Conversion
I have found little webber tin pans that hold abut 20 0z and fit under the transmission so I can drain everything out of it
It appears i should now have enough info to attempt these tasks. Gonna try this weekend.
One last question though, where exactly is the engine?
Blair White
Pacific Beach, CA
[quote=blair]One last question though, where exactly is the engine?[/quote]
I remember when my Mum and the neighbor's wife both had new VW Beetles. I'm talking 1960s. One day Mum couldn't start the car. The neighbor lady was right there, gossipy pair they were, so she says, "have a look under the bonnet."
Mum lifts the hood and exclaims "Blimey, no wonder it won't start, someone's nicked the engine!" To which the neighbor lady replies calmly, "Don't you worry love, I've got a spare one in the boot."
Nick Tonkin
Yep I work at West Marine Channel Islands. It is part time but I am there about 4 days a week. I also fix/repair sailboats as a business.
Duncan McNeill
Channel Islands
I was getting ready to buy an expensive oil extraction pump. Then I found out that our local Discount Marine shop rented a very nice heavy duty one for $4 a day.
And then they keep the messy thing the other 363 days that I'm not using it ;-)
Worth checking around.
Paul
Paul & Ann -
"Freestyle" -
1985 C36 #454 -
North Puget Sound, WA
David S. Power
Two If By Sea #1687
Burnt Store Marina
I too endorse the Oil Boy. Simple, always works, nothing complicated to break. I even use it to suck out old gas out of my chainsaw, and power washer!
Seems they may be discontinued, but here is what they look like, and others similar in design are readily available.
http://www.amazon.com/Tempo-Oil-Boy-Fluid-Extractor/product-reviews/B000...
Steven Jones
Maléna C36 2164
Seal Beach, CA
Steven Jones
C36/375IA FaceBook group administrator
Seal Beach, CA, USA
C36 #2164 Maléna 2003 Mk-II SRig/FullK, Long Beach, CA
stevenjones21@gmail.com
I've set aside March as my month for preparation for the Inside Passage trip, April to relocate the boat to Puget Sound, and mid-May to push back on my trip to Alaska. *IF* I remember to do it...I will try to video my annual engine maintenance (oil, filters, belt, impeller, HE zinc, etc) and put it on YouTube. I'll put a link here on C36IA, of course.
I still have a couple articles to write as promised: 1) Rebedding a chainplate, and 2) replacing the furler drum. I have all the photography for these but too many things on the To-Do list at the moment. Sorry.
Ok, so I'm finally getting around to this, and already have a problem. I bought the cheap harbor freight tools pump and the intake hose just collapses when I pump it.
Whats wrong with this picture?
Edit: Drain hose directly in to intake port.
Yep, that did it.
Blair White
Pacific Beach, CA
All good Blair?
Apologies to Blair and others expecting me to meet my commitment to video the annual preventive maintenance on my boat. I just spent three days trying to do this, without a camera person, and all the attempt did was slow me down. It's taken almost three days to do what I would ordinarily do in less than a day AND I got crappy video. Using a min-tripod sometimes the camera would fall over mid-activity; hand holding it's so shaky that it's useless to edit.
Next year, I will have to get a volunteer to be the camera person.
In the meantime my next post may serve as a checklist for this periodic/annual maintenance check.
When I do the annual preventive maintenance on High Flight I take it by system, not beginning the next system until I'm through with the present one. Here's the sequence I used over the last three days. Note this is on a 2002 Catalina 36 Mk II, s/n 2109.
1. Open the engine compartment fore and aft, get all-round access, have tools and replacement parts (fuel and oil filters, zinc, Racor, new belt, new impeller, oil, ATF fluid) at hand.
2. Fuel system:
3. Transmission
4. Packing gland
5. Raw water cooling system
6. Closed cooling system. Check the coolant level in the overflow reservoir in the cockpit locker. Today I needed to add about a cup of 50/50 antifreeze premix.
7. Oil
8. General
Larry,
Thanks for sharing. Excellent write-up.
Nick, yep, all is good.
Once I re read your post about connecting the drain hose directly to the pump intake port, it worked like a charm.
Thanks again for that tip.
Fuel filters next.
Blair White
Pacific Beach, CA
Blair,
There's some variability between model years. Since we both have the same model year, here's my procedure. All of my extra steps here are important to reduce engine cranking time anytime the fuel filters are changed. You should have a few cups of clean diesel handy before you begin.
RACOR 200R Manual: http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB4QFjAA&url=http%3A%2F%2Fwww.marlow-hunter.com%2Fexport%2FVendor-Manuals%2FRacor%2520200RMAM.pdf&ei=Sj0MVZmMF8iryAS434D4DA&usg=AFQjCNFw_rYCGWBhZDnv9Dsx3XzKjKfT7g&bvm=bv.88528373,d.aWw
