How to read the M35B Tranny Dip Stick, and
Bruce Stanley
My M-35B Gear Box Dip Stick OIL reads about
1 inch up from the bottom.
Is this correct?
(photo attached)
Bruce Stanley/C36 MkII #2282 M35B
Sydney Australia
Gsmith's picture
Gsmith
Bruce
The level reading is taken with the dip stick unscrewed and resting on the casting. See attachment
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
M35A Oberdorfer conversion
Channel Islander's picture
Channel Islander
Hi Bruce,
You have access to all the manuals for our boats and equipment since you are a paid-up Member of the Association.
On the main menu under Members > Technical Articles > Manuals you will find a link to a PDF of the M35 owner's manual from Universal. The transmission maintenance section is on page 31.
hope this helps,
Nick
Nick Tonkin
newguy's picture
newguy
Completely unscrew and clean. Insert dip stick, allowing the dip stick threads to just rest on the casing.  Remove and inspect.  Ideally, the fluid just reaches the line on the dipstick (about 1/2" from the bottom).  Anything significantly past this line is overfilled and anything below this line is underfilled.
Bruce Stanley
for the Replies and directions.
BruceS
Online
I found a way to check the fluid level vs using the dipstick which I could never tell where the level was. Use a clear straw (or plastic tube) marked with an insertion depth and the full level marked. Insert straw to insertion depth put finger on top end and remove. The fluid should show and you can actually see it to the full level mark.
Looks good!  Mine is about the same.
alfricke's picture
alfricke
Just to be clear, it looks to me that the answer to your question is a big NO (it is not correct) and as I understand it, overfilling trani fluid can cause big problems.
Al Fricke
S/V Jubilee San Francisco Bay
Catalina 36' MkII  #1867
Universal 35-B
