My M-35B Gear Box Dip Stick OIL reads about
1 inch up from the bottom.
Is this correct?
(photo attached)
Bruce Stanley/C36 MkII #2282 M35B
Sydney Australia
Is this correct?
(photo attached)
Sydney Australia
Theme by Zymphonies
Bruce
The level reading is taken with the dip stick unscrewed and resting on the casting. See attachment
Gary Smith
93 MK I, Hull #1231
Std rig; wing keel
M35A Oberdorfer conversion
Hi Bruce,
You have access to all the manuals for our boats and equipment since you are a paid-up Member of the Association.
On the main menu under Members > Technical Articles > Manuals you will find a link to a PDF of the M35 owner's manual from Universal. The transmission maintenance section is on page 31.
hope this helps,
Nick
Nick Tonkin
Completely unscrew and clean. Insert dip stick, allowing the dip stick threads to just rest on the casing. Remove and inspect. Ideally, the fluid just reaches the line on the dipstick (about 1/2" from the bottom). Anything significantly past this line is overfilled and anything below this line is underfilled.
for the Replies and directions.
BruceS
