I have been given the go-ahead by the Admiral to purchase a new sail.
Both sails are original (1999) and have a similar amount of wear (moderate, but still reasonably good shape). The issue arose when crossing the strait last weekend in 25+ knots - only 1 reef in the main and no foam luff in the jib... and would have liked to have been reefed a bit more.
So I started getting quotes for a second reef point in main and foam luff in jib... Noticed all stitching needs a look at, etc.
So... since I can only buy one now (the other maybe in 2 yrs).
Which one would you get?? (given similar wear..)
Howard-
I would opt for the Genoa 1st. That's maybe 65%-70% of the boat's horsepower and most important sail. We just purchased one last year from a local sailmaker- Doyle. They tend to run on the high side but have a very good reputation. They advised not using foam in the luff- suggesting a luff rope instead (an internally stitched line)- which we did. The sail wraps on the furler tighter with luff rope....less windage when partially furled or fully wrapped. They also incorporated a sewn- in trim line to help you adjust the jib sheet to the correct point in the deck track- helps achieve proper sail trim. After using this to establish efficient trim, I've also noted that our tracks don't extend as forward as far as they should (with sail > 30% reefed) - which Doyle warned me about.
Our old Genoa was like a bag (Original to the Boat). The new one is flat and we've hit 7-8 knots under 15-20 knots of wind with just the Genoa- from close hauled to a reach. Of course she points higher with the main out too. 406 SQ Ft, 135% Genoa, UV Cover. Sunshade, 7.77 Oz Dacron. $2913 (2013 Price).
Good luck
2005 C36 MKII #2257
Thanks Paul;
I have had one quote from Doyle, interesting that it was 8.18 oz dacron and a little less than yours, but in Cdn dollars, so price sure varies...
Howlin. I bought a 125 genoa and 2 reef pt main from National sail supply in Florida. Very happy with price. I think $1800 for genoa similar for main. Well built and good shape.
Main is full batt 8oz. Talk to Dirk. Email me if you need better contact info. He will ship to canada or pick it up in Blaine
Gibsons Harbour BC
www.landsendbc.ca
Howlin, let me quote you on your sails, I have sold a great number of Mack Sails to 36 owners and all are supper pleased with product, design, service and our price is second to none. I give c36 members a bonus price discount. Email me off line at chiclasser1@yahoo.com and I can give you a price and references.
Chic lasser
Past Commodore c36ia
Great Lakes Rep Mack Sails and Rigging
