Heat Exchanger Zinc
9 posts / 0 new
WindEnsemble's picture
WindEnsemble
Heat Exchanger Zinc
Hello everyone,
Getting ready for the sailing season down here and have been doing a bit of routine maintenance. Things are going well so far, but I am getting conflicting information regarding HX zincs. Research suggests that the 2" HX requires longer, narrower zincs and the 3" HX requires shorter, thicker zincs. My HX measures 3" at the end cap AND the PO left replacement zincs on the boat (in the original package from Universal). They are the shorter, thicker variety and the part number on the package matches the replacement parts list inside the lid of the blue plastic Universal box that came with the boat. So far, so good. But, when I went to remove the old zinc the socket that fit my new zinc was too big to fit the head of the old zinc. Odd…Got the correct size socket and discovered that the installed zinc is the longer, thinner variety. Obviously, I need a different zinc to install, but has anyone else seen this conflicting information? Is HX diameter measured the ID or the OD?
S/V Wind Ensemble
1987 C-36 Wing Keel
Universal M25XP 23hp
Hull #705
Coastal Alabama
Don't think the HX size is the relevant factor here (we replaced our old 2" HX with a 3"HX, the zincs were the same).
The important thing (other than the thread size fitting) is that the zinc is not so long that it hits up against one of the inside tubes when its installed. We buy the generic ones at WM, which are about 1/4" to 1/2" too long, and then cut them down with a hacksaw.
William Miller
I buy the zinc that screws into the plug and have to cut down till they are about 3/4 in long. You can take the cap off the side of the HX and see how far your zinc will go in
WindEnsemble
Great. Thanks for the prompt replies.
Jeff
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
WindEnsemble
Thanks, Stu.
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
William Miller
My 25xp HX does not look like Stus wish I could put that long of zinc in there,as the other guy on the link said take off the end and check
WindEnsemble
Just closing the loop. My 3" heat exchanger requires the following zinc specs:
1/4" NPT plug, 3/8" diameter pencil zinc, 2 1/2" length. The zinc itself is stamped CM E0 A. As I mentioned before, this does not match the replacement parts list on the Universal Replacement Parts box (inside lid) that came with the boat, nor the actual replacements that were in the box. I'm guessing a PO (there were 2) had the original HX replaced. Anyway, I hope someone else finds this information helpful.
Jeff
S/V Wind Ensemble
1987 C-36 Wing Keel
Hull #705
Coastal Alabama
Thanks for sharing that, Jeff. That is one of the things that makes this community so great; we are all in it to help each other!
