I took my genny off yesterday and need to lay it out on the driveway and scrub it to get some mildew discoloration and some dirt marks off. After 10 years, the sail cloth is still in fine shape generally, but the main discoloration is mostly mildew-related, and mostly within an area about 30 inches wide here and there along the full length of the leech, and on the UV cover. I suppose I could let my sailmaker put a new UV cover on, but that wouldn't take care of all of the discoloration.
If I lay the sail out on my driveway and get down on my hands and knees with a scrub brush, what cleaning product would be the most effective, while doing the least damage to the sailcloth?
I have thought about a vinegar solution, about baking soda, about boat soap, about... Well, what are your ideas?
(And yeeesss, I did a search first.)
Hello Larry
I asked our sail maker the same question. We had considered having the sail cleaned professionally and he dissuaded us.
He said to use a mild solution of cloths washing soap, no bleach just soap etc. Rinse thoroughly he said there should be no soap residue. When done take the sail and hang it he suggested going for a sail to dry it.
Hope this helps
Happy 2013 to you.
2000 Catalina 36
Hull #1915
M35B
TR Fin Keel
"I can teach a man to sail, but I can never teach him why."
Timothy E. Thatcher
Downloaded from a sail manufacturer/repairer that I know: NOTE - AVOID PAVEMENT!
Cleaning Dacron sails:
Clean sails on a smooth surface. Avoid pavement and gravel or you will find
yourself sanding the back of your sail as you meticulously clean the front.
Use a mild soap solution and fresh water.
Use a soft bristle brush to remove dirt and salt.
Rinse thoroughly with fresh water. Keep rinsing until all soap residue is removed.
To remove oil or tar stains use a small amount of lighter fluid.
To remove mildew sailcloth manufacturers recommend a highly diluted solution of
Sodium Hypochlorite (3-5%). Because it is toxic to you and the environment, we
(Port Townsend Sails) object to the use of bleach except as a last resort. We have also
heard and common sense leads us to concur that bleach strips the coating from
thread and leaves stitching vulnerable to UV damage.
Never use bleach on nylon or laminated sails!
A hot tip for cleaning sails from PT Sails staff: Dilute 2Tbs Woolite and 1-2 cups
vinegar in 1 gallon water. Some of our customers have had great luck with this
solution.
I tried Fels Naptha soap on any stubborn spots. someone on the list had mentioned it last year. Great stain remover on laundry too.
Laura Olsen
Past Commodore
S/V Miramar
Edgemere, MD
I usually put mine in the grass and use Oxyclean. Let dry and turn over and do the other side.
What I did was to lay drop cloths on my patio, then placed the mainsail accordion-style on that. Avoided grass due to possible green stains.
One section at a time I gently scrubbed the sailcloth with dilute oxyclean in warm water, taking care not to abrade while working out most of the dirt.
Oxyclean does a quick number on any black mildew spots (oxyclean contains a stable form of hydrogen peroxide).
I also used Oxalic Acid (USP powder dissolved in water) to take care of the rust spots.
This from Wikipedia:
[I]Oxalic acid's main applications include cleaning or bleaching, especially for the removal of rust (iron complexing agent), e.g. Bar Keepers Friend is an example of a household cleaner containing oxalic acid. Its utility in a rust removal agents is due to its forming a stable, water soluble salt with ferric iron, ferrioxalate ion.[/I]
After rinsing well with fresh water, I hung the mainsail to dry in the backyard.
It was summertime, so it made a great shade cover for the yard!
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
