Hi all,
Does anyone have any thoughts on installing remote switches for the electric windlass?
From my experience, raising the anchor singlehandedly is a quite a show, with running back and forth from the up switch at the bow to the helm. It would seem much easier to drive the boat toward the anchor and at the same time, pull the anchor in.
Maxwell has some cool remote wired and non-wired controls (expensive) and panel mounted switches. I was thinking of installing a panel switch somewhere near the helm...
Thanks for any ideas,
Erik
#1939
Maxwell 800, up/down foot switches with solenoid.
C36, 2001 #1939
Monterey, CA
Hello Erik,
I found this post when searching the subject of remote contolled windlass.
Wondering if you ever got any answers or if you've adapted a remote control for your windlass. I plan on doing some single hand cruising and need to address the anchoring issue. Or for that matter has any other owner added a remote control to their windlass? Any help would be appreciated.
Sam
Capt. Sam Murphy
1994 Catalina 36, Hull 1327
Shoal draft, two cabin model.
Panama City, Florida
I have not done this myself - however I would imagine that this can be done very easily. Use an auto start relay - that can handle 30AMPs easily - and place it next to the switch underneath the foot switch. Then bring 2 18AGW wires into the helm panel and place a momentary switch on this panel. When you press and hold the switch down the relay contacts will provide current to the windlass motor. To raise the anchor - I normally pull the rode and the chain in as much as I can by hand until the chain is directly vertical - this means that the anchor is directly below the bow. Then I lock the chain to a cleat and drive the boat forward. This will break the anchor loose. Then while at the helm you can raise the anchor until you see it at the bow. In my case the anchor will not set in its cradle and I have to raise it by hand and place it on its holder. So I go to a dock and finish the job. Or if there is no dock then hopefully there is plenty of room for you to motor slowly and go to the bow to adjust and tie down the anchor.
Coyote Point, San Mateo, CA.
Sam,
I'm in the process of installing a maxwell windlass and it came with a switch that installs at the helm. I was reading an article about a windlass install that was posted by Gary Teeter and in his description he says: "A pendant to control the winlass is passed out through the starboard opening window. The pendant we use was designed for industrial hoists and has up and down buttons."
I really like this idea, since it gives a lot more mobility than a fixed switch at the helm. As I've looked through various industrial pendants (pendant stations) that are available, for running hoists and power winches, they all seem to be for AC power. I don't know if they could easily be adapted for a 12 volt windlass?
Paul Meyers
1986 Catalina 36
Hull #615
Ventura, California
I have a remote control for the windlass, and I love it!
Originally the boat had only the stock "up" foot switch at the bow.
I installed a second foot switch for "down", and also installed the solenoid unit needed to switch back and forth.
Then, I installed the wireless controller to control the solenoid.
Now, as I approach the anchorage, while at the helm, I can release and drop/set the anchor single handing.
When ready to depart, again the remote windlass makes it easy to "up anchor" and pull away.
Here are some photos of all that:
Captions:
1) Starting point, single switch
2) Second switch and solenoid installed
3) Detail of solenoid/receiver wiring
4) Solenoid unit
5) Remote control fob for windlass control
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
Rick, that looks great but where did you buy the parts please?
Sam
Capt. Sam Murphy
Rick, How and where does the receiver for the remote install?
Paul Meyers
1986 Catalina 36
Hull #615
Ventura, California
You will find a lot of diagrams etc on the Maxwell site:
[URL="http://www.maxwellmarine.com/gen_accessories.php"]http://www.maxwellmarine.com/gen_accessories.php[/URL]
If you open some of the PDF documends there are details on the various instalations.
Ross & Joanne
Wavelength
Saint John NB
RKYC
C36 #658 TR 1987
I bought all my Maxwell stuff from Defender. Great prices, good service.
Here is additional detail on the remote/receiver (second photo).
The receiver with it's antenna (green tape) sits right next to the solenoid.
Hey, if I could drill the deck, mount a footswitch, then wire the solenoid with big cables and hook up a wireless, anybody could do it!
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
Great pictures Rick. Very useful for me since I am doing a new install of a Maxwell windlass.
Paul Meyers
1986 Catalina 36
Hull #615
Ventura, California
