Holding tank vent through hull fitting
Channel Islander's picture
Channel Islander
Hi friends,
As you know Peggie Hall and the conventional wisdom hold that the holding tank should be vented with a (preferably two) one-inch hose connected to a standard open through-hull fitting installed just below the rub rail and covered with a clamshell.
Has anyone done this on a C36?
It makes sense to me that it's the right thing to do, but I'm nervous about the vent coming under water on a hard heel.
Nick
Nick Tonkin
Nimue's picture
Nimue
I have done this but with a slightly smaller dia hose, I think it's 3/4", and I have no clamshell over the thru-hull fitting. I have had no problems even during some extremely rough crossings of Georgie Strait.
Catalina Direct has a stancion which has a vent built into it's base. This is the type of vent I had on my 30' as well as GWTW. Would prevent your concern of a vent on the side of the hull. Con is that overflow may run down your deck.
