Epoxy for in-hull transducer mounting
SailorJo
What is the best epoxy to use when mounting an in-hull sonar transducer in the boat?
Owner of a Mk 1 C36 Hull # 379 commissioned December 1984.
Fin keel, standard rigging.
Boat is based in Nanaimo, B.C., Canada, where you will find one of the finest cruising areas in the world.
Maine Sail
Airmar specifically advises against epoxy. They suggest silicone. I am not a huge fan of silicone because of the contamination it causes so I use Sikaflex 295UV which is safe for most plastics..
