How many gross tons?
12 posts / 0 new
RPowers's picture
RPowers
Hi,
I'm filling out a form for the coast guard.
How many gross tons is a Catalina 36?
How many gross tons is a Catalina 27?
Thanks guys!
-Rick
Captain Rick Powers
(USCG OUPV)
1999 Catalina 36 mk II
Hull#1745
Std Rig, Fin Keel
Palo Alto, California
San Francisco Bay
My CG documentation has our boat listed as 11 Gross and 10 net. I'm not saying that is right, but that's what we have.
I am with you Duane , ours is the same on the CG doc papers.
caprice 1050
The CG Certificate for Caprice is 15 Gross and 12 Net Tonnage.
Mike,
You are NOT supposed to count the weight of the liquor locker! :D
The forms you fill out with Transport Canada to federally register a boat have a length/width/depth/height kind of formula on them. Ours worked out to about 8.3 for the value to be shown on the plate. Probably metric tonnes I think.
Remember, the "tonnage" is not weight, it's internal volume. For the CG license, for a MK II, 11GT is correct. Its on the document6atiion papers but Catalina will provide it if you ask too.
RPowers's picture
RPowers
Just got off the phone with Catalina in Woodland Hills.
To calculate Gross Tonnage, you need:
Length = 36.33
Beam = 11.91
Depth = 5.5 (not draft)
To calculate:
((L x B x D)/100) x 0.5 = [B]11.9 Gross Tons[/B]
Captain Rick Powers
(USCG OUPV)
Hull#1745
Std Rig, Fin Keel
San Francisco Bay
caprice 1050
Rick
Do you know if this the same for a wing Keel C36?
I am pretty sure the volume inside the hull is what this formula tries to approximate (and it is just an approximation) and then the volume is corrected for the amount of cargo 'tonnage' the vessel could hold. The whole formula and tonnage measurement is pretty antiquated, but it persists.
So, the type or weight of the external keel means nothing in this case.
I understand you stated that the Coast Guard was asking the question, with the formula now understood, is the answer the same if someone from a Mexican drug cartel asked this question? It may have an effect on resale of our boats south of the border, corrected I think it translates to 22,000 gross kiloage.
Lol !!!!!!!!!!!
