No Heat from Mermaid Heat Pump
richie30's picture
richie30
I have the Mermaid heat pump / air conditioner unit that came standard on the C36 / 1998
My heat is not working, and I tried to troubleshoot today.
Any thoughts?
I have water going through the system, and the compressor and fan are running, just blowing cold air.
Any thoughts appreciated!
Rich
Rich
Richard & Joan Bain
PAZZO Hull#1670
1997 Catalina 36 MK11
Bayfield, Ontario
My Day Job Below
www.richardbain.com
www.bineapress.com
rhardison
Rich
There could be several things to look for,
1) make sure you have water thru the system
2) make sure your thermostat is turned up to a higer degree
3) loose or bad connections on the themostat
4) you could have a bad solenoid on the switchover valve
5) bad switchover valve
if the switchover valve is stuck you will need an HVAC tech to change that out
hope this helps!
Richie Hardison
Sydney Lane
1984 C36 #332
New Bern, N.C.
