I cannot find replacement caps for our 1992 C36. They are blue plastic, and two are now cracked. Any advice on where to look?
Ed and Nancy Lazarski
1992 C36 Triple Pisces
San Diego, CA
San Diego, CA
Theme by Zymphonies
If you are referring to the deck fills you can buy replacement blue caps at Catalina Direct.
Mike Ogline
SHADOW #1831
2000 SR/WK
Deltaville - Chesapeake Bay
These?
[url]http://www.catalinadirect.com/index.cfm?fuseaction=product.display&produ...
S/V Wind Ensemble
1987 C-36 Wing Keel
Universal M25XP 23hp
Hull #705
Coastal Alabama
Just as an fyi. I had those caps on my 1988 C30. One spring my diesel quit; water in the fuel. 2 gallons of water in the fuel. I couldn't figure out where it came from, but eventually traced it to the cap. Evidently the recess for the winch handle had filled with water, frozen, expanded and cracked the bottom of the recess all the way around. Melting snow and rain must have run down the deck, into the recess and into the tank. Strangely enough, another Catalina in my marina had the same problem that winter.
Maybe an isolated incident, but I put tape over the caps each winter after that until I traded the boat on my C36.
